My RV-8 build
Date:  12-7-2011
Number of Hours:  1.50
Manual Reference:  Page 7-5
Brief Description:  Left wing leading edge part #4
I'm still waiting for my order of Proseal and other items from Van's, so, tonight, I removed the left wing leading edge from the wing.
I removed all the ribs after marking their position within the leading edge.
Dimpled all of the holes to #40 that were previously final drilled and deburred.
Also dimpled the access plate for the stall warning system and also the mounting holes for the stall warning bracket.
Last week, I received my order from Aircraftspruce. I ordered a tube bender, some 3/8 5052 aluminum pipe for the return lines in the tanks, along with some fittings, and also a pitot tube cover.
I'm hoping to get my order from Van's by the end of the week so I can finish off the right tank. In the mean time, I'll dimple the left wing leading edge ribs tomorrow, scotchbrite, clean, then prime the skin and ribs.
LEft leading edge back in the cradle
Dimpled to #40
Dimpled to #40
Left wing leading edge completely dimpled.
